Android is built on LinuxThanks a lot, this is for Linux? I thought it was for android
So which one you think is best? Android or Linux? About stability, no freezing smooth and so on. I just reseved the box and I am thinking about itAndroid is built on Linux![]()
Android is bassicly a Guid for LinuxSo which one you think is best? Android or Linux? About stability, no freezing smooth and so on. I just reseved the box and I am thinking about it
Use default Linux mode, works fine no issuesSo which one you think is best? Android or Linux? About stability, no freezing smooth and so on. I just reseved the box and I am thinking about it
It's really easy...Ok i will try. I hope i will manage to set up it.
Thanks for the help
I can't find pre-release in system menuItäs siple to change to Androud. Just select pre-release in system menu and install. But I don't see why you would like to do that. The Android is not supported yet and frankly not realy usable. The QT Linux version is stable and works perfectly - including subtitles (on the Swedish channels, I am Swedish). You should use it in m3u mode, not stalker.
The seller ask me send him back the box and he will do something for android mode. That because the Linux mode was updated the first time when started.
That will take about 2 months.
If ican do that my self, and is safe, where can find, download and instructions how to do it the android?
Thanks in advance
As I told you we support Rapid Iptv here
