VLC Technical Issues and Support
Try to restart vlc settings to default, then restart vlc and try again,
Let us know,
Harry
Thanks! i have ask him..
he have to open file m3u with notepad and copie user password in he s line or you have to give him that i think
Yes, but that will not working. Also he have checked the uppercase lowercase letters but no sucess..
Hello all,
VLC had worked flawlessly before for me but since 3 months ago I'm having problems where every 5 seconds the streams stops for 2 seconds. I have tried installing earlier versions of VLC. Tried changing the streaming buffer cache but nothing has worked for me.
I also use Kodi on an Xbox One S connected through wifi and it works without a single problem. Never have seen a buffering problem.
VLC is on a wired PC with 1Gb/50Mb connection.
If you have any ideas for me to try I would appreciate it.
Thank you.
Forgot to say that I have tried:
m3u_plus&output=ts
m3u_plus&output=m3u8
m3u&output=ts
m3u&output=m3u8
(Sorry for the double post but I can't see any "Edit" button on the earlier post.)
I run an iptv .m3u file and have all chanels.
BUT
every 10-15 sec the chanel goes black for 2 sec and the stream seems to reconnect the the chanel is on again, and it continues .....
What did i miss ?
THX
Hello. I am using VLC player via Xciptv. Turkish characters appear as boxes in subtitles, for example: ö,ç,ş,ü etc.
How can I solve this problem? I don't want to use exoplayer, I think VLC player is better.
Thanks.
Reactions: legacy2023
