Copy past the url playlist linkwhat line do i have to use for vlc player?? i always get no url found????
i have several links m3u whit option etc. whitch one should i pick
Download m3u file and drag and drop into VLC.it has 3 options hls, rtmp, mpegts i have used them but no results. no url found. on iphone no problem it works
Mpegtsit has 3 options hls, rtmp, mpegts i have used them but no results. no url found. on iphone no problem it works
having problem setting up my rapid on my vlc just get wrong message that it couldnt open the mlr.. and ive followed the tutorial.
the thing i found wierd is that all the other links i se ends with mpgets but my links ends with =ts
Hi Guys
I want gieve a Testline for a Guy
I gieve him http://clientportal.link:8080/get.php?username=------ &password=---&type=m3u&output=ts
And he cant oopen it ?
is this Link Right?
because your clients use VPN, that is why.It seems - it's not correct. Does not work for me![]()
Probably, but why?Hi there is it possible to use VLC on android to view iptv from here,if so how?thanks.
