There is always hosts problem... Rapid IPTV must change hosts serverproblem suddenly is back now! always prime time issue
what channel? And is this now? Because at the moment for the last 20 minutes their server was completely downWell they should have said that before I signed up for a account, I have problems a couple of times a day that I can't watch any channel!!!!
VLC kon de MRL 'http://portal.rapidiptv.com:8080/live/vyTc21nhhj/vTzF0cvGAG/5780.ts' niet openen. Controleer het logboek voor details.
Sorry for the dutch but it said VLC could not open the MRL, check logbook for details......zzzzzzzzzzzzzzz
Yes it was around that time and yes everything is working again now but this happens a couple times day! I really don't wanna complain much but this aint good, please ******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN ******* get your things together.what channel? And is this now? Because at the moment for the last 20 minutes their server was completely downWell they should have said that before I signed up for a account, I have problems a couple of times a day that I can't watch any channel!!!!
Go in settings, vidéo, accélération, and uncheck two options about codec and média codec.Hi ! Can someone help me with VLC on mac ? Some Channels drop sometimes I have a lot of problems... Kodi works fine on my mac but some channels don't work sometimes (the screen is laggy with a lot of pixels on it but no problem with vlc with these channels so I don't understand that). So which settings coud I use with vlc on mac ? Thanks
Try with Windows. Let me know thenI would like to use kodi and no Vlc but look. 2 pictures of the same channels at the same time. The first one on vlc and the second with Kodi. I don't undersand some channels works great with kodi but sometimes some channels are just like that...
I can't... I just have my MacTry with Windows. Let me know thenI would like to use kodi and no Vlc but look. 2 pictures of the same channels at the same time. The first one on vlc and the second with Kodi. I don't undersand some channels works great with kodi but sometimes some channels are just like that...
Disable accélération in your kodi settingsI can't... I just have my MacTry with Windows. Let me know thenI would like to use kodi and no Vlc but look. 2 pictures of the same channels at the same time. The first one on vlc and the second with Kodi. I don't undersand some channels works great with kodi but sometimes some channels are just like that...
Thanks I will try that. Look my Vlc settings what should I do ?Disable accélération in your kodi settingsI can't... I just have my MacTry with Windows. Let me know then
See here http://rapidiptv.com/threads/guide-playing-videos-in-full-hd-smoothly-vlc.1337/ and see post about harryporter too.Thanks I will try that. Look my Vlc settings what should I do ?Disable accélération in your kodi settingsI can't... I just have my Mac
It's for Windows... I don't have the same thing on my macSee here http://rapidiptv.com/threads/guide-playing-videos-in-full-hd-smoothly-vlc.1337/ and see post about harryporter too.Thanks I will try that. Look my Vlc settings what should I do ?Disable accélération in your kodi settings
So at the end of my list I add a line like that ? I'am new so I dont understand what you mean...The problem is with your list as you are using mpeg list for vlc and hls for kodi, correct me if im wrong. You should use mpeg list for Kodi. At the end of your list line put this instead what you have now type=m3u_plus&output=mpegts . Then configure Kodi like explained in this guide http://rapidiptv.com/threads/kodi-advanced-settings-for-smooth-play.956/
