azem
31
hi to all
why xc plugin do mot work anymore?
can you help me please
best regards
azem
31
Hello
Is there a solution for XC Plugin ??
I did not get an answer
or it just does not work for me
best regards
Raffi
it does not work in general, also for me too.
can someone help?
thanks and best regards
Hans Arsch
Doesnt work for me - the plugin always tells me "Playlist Error: HTTP Error 404: not found".
Any suggestions?
zwollefm
Meerzenders
33
NL
www.meerzenders.eu
zwollefm
Any suggestions?
I suppose you have a working subscription ? Your enigma2 macadres should be fill in your dashboard. Thats the macadres it appears when you open the plugin or ask your reseller to do so for you
Hans Arsch
yes, I have a working subscription, but I had not entered my mac-adress...
(the tutorial does not say that I have to....)
Isnt there any other way than adding the mac? If my understanding is correct, I cant use the line on any other device... right?
zwollefm
Meerzenders
33
NL
www.meerzenders.eu
zwollefm
Login to your dashboard ==> manage lines ==> Add Enigma
Or ask your reseller to do for you
If you have only 1 connection you can connect only one one device. When i close my plugin i can use it on other device. But you make sure one connection is fully closed before opening on other device
Furqan
Slight funtionality differences. Mainly the mac address validation in xtreamtv and auto plugin updation. If you have only 1 connection then with xtreamtv you wont be able to use other apps or plugins as the line will be dedicated on xtreamtv plugin.
Hans Arsch
Sorry, I cannot get xcplugin to work.. it always says Playlist Error: HTTP ERROR 404 not found ( I used the new link from reply #206)
Bartje
bartje
Is this plugin still working? Since a few days it keeps loading. Prefer this plugin because I can use it also on smarttv.
