IPTV Community
Administrator
Jun 3, 2015
683
1,736
214
iptv.community
Here is a plugin for Enigma2 devices.
1. Unzip the file then upload the files to your E2 box
2. Edit the user file with the username and password of the line (etc>enigma2>xc_e2_plugin.xml)
Reboot your device then the plugin should be ready to use.
This plugin maps out all Boquetes like mag portal.
Enjoy
Here is a pluggin for Enigma2 devices to use Rapid Portal
2. Edit the user file with your username and pass (etc>enigma2>xc_e2_plugin.xml)
Reboot your device then the pluggin should be ready to use.
This pluggin maps out all Boquetes like mag portal.
Enjoy
Thanks for the share !
Yes but look at this config file and tell me how to configure it for Rapidiptv as i dont se any way of doing it?
the file located at etc>enigma2>xc_e2_plugin.xml
should look like this
<?xml version="1.0" encoding="UTF-8" ?>
<items>
<plugin_version>0.1</plugin_version>
<xtream_e2portal_url><![CDATA[http://clientportal.link:8080/enigma2.php]]></xtream_e2portal_url>
<username>YOURUSERNAME</username>
<password>YOURPASSWORD</password>
<esr_id></esr_id>
<ar_id_start></ar_id_start>
<ar_id_end></ar_id_end>
<security_key></security_key>
</items>
@sibuk Don`t post the things that you have not tried and that don`t work OK becouse RAPIDIPTV DONT HAVE ANYTHING LIKE </xtream_e2portal_url>
You obviously havent a clue what you are talking about, I have been using this pluggin for months and have tested it today on 2 enigma2 receivers using rapid iptv and IT DOES WORK !!
I wouldnt post anything I havent tested or post something that does not work !!
It works 100%
Hi when i go to the plugin on my enigma 2 box i get an error it says..
PLAYLIST ERROR:
no element found line 1, column 0
URL:
http://portal.rapidiptv.com:8080/enigma2.php
Has anybody else had this error? or know how to resolve it?
Many thanks
It means that your password or username are wrong so check it but for me this plugin dont work even after when you have portal options. I have Black Hole image.
Let me know if it works for you so i could do with my box also something,
Installed this last night on my box works a treat thanks a lot!! Followed exactly as per the instructions no problems
It didnt work on my box (black hole). The plugin starts but crashes after a while. It says lines are out of reach...
Any other IPTV plugin that works great?
Just want to say a big thank you for posting this.
I have wasted hours studying how to get this running in iptvplayer and even more converting to bouquets and losing my channel numbers.
This plugin is superb, installed easily, video on demand segregated from live tv, channel groups in tact and epg info where available. Ace.
Reactions: Orbit IPTV
Yes mate a few members saying it did not work but I have installed it on a few different e2 receivers with openATV and HDMU images and it works spot on.
Glad it worked for you mate
