Just bought a formuler S Turbo, does not want to load the Channels list in MyTVOL V1.
Hi when I try to put the link to the channel list in the S Turbo it always ends with "Data Fail"
I have tried :
  1. http:....
  2. https:...
  3. With VPN
  4. Without VPN...
Nothing works..... Only when I download the M3u File and point MyTVonline to a local file.... It works...
Other Android apps (Kodi) have no problem loading the M3u File Online...
hello. im using x96mini thats stuck and proberly needs flash of new firmware flash.. any idea where i get this
Hello guys, my name is big and im new here.
I have some technical issues with siptv. Maybe you could give me some advice.
I bought siptv like 4 years ago and used it since then (on firetv stick).
Somehow since 1-2 Weeks siptv app showed me that my siptv is not activated and now i use it7 days as trial version.
Now i cannot see anything and the support of siptv is not responding to my mails.Did anybody of you faced that issue?
Yours sincerelyBig
Yours sincerelyBig
That's strange did your Mac address change ? Did you switch from wifi to lan with adapter ?
If you did not change anything and if it's same device, send a message to app developer support. And make sure that you've installed to APK from their official website and not s fake one.
Official APK source: http://apk.siptv.app
Yours sincerelyBig
Each TV has 2 MAC addresses (1st is WiFi, 2nd is Ethernet) and a 2nd MAC has activated automatically after you switch to another connection type and restart the app. So it appears you can use either connection just reboot the app on change.
Actually my Mac didn’t change.
i use the same device with same Wi-Fi.
The devs are not answering..
I send three mails within one week to info@siptv.app but never received any response.
Hey guys so i finally bought a android box since my lg tv started struggling. Im new to this and there are alot of different iptv apps out there. which is recommended. i want something that is light, and user friendly. Would be a bonus if i can search in vods.
IPTV on my android box and Galaxy Tab (also running android) has stopped working since last week though IPTV still works on my computers and TVs. I suspect my IP has done something to action this as a while ago my Samsung TVs stopped connecting and when I researched it I found I needed to change the DNS settings to overcome the IP blocking. Does anyone have any ideas about this?
