Paste your EPG link in bitly.com to shorten it. Had the same issue with Perfect Player as you did. After that it worked perfectly
Tnx for help
Just tried but still no EPG on exyu or uk section
Have tested EPG from dashboard on my Android Tablet with GSE app now. .
It dosen’t work.
Tested on IOS and GSE app at the same time.
It worked.
Also tried to login in to dashboard on android dosen’t work.
Login to dashboard with IOS at the same tine worked.
I think that the problem has somethibg to do with https:// not working in Android.
It dosen’t work.
It worked.
It seems to me that you are abaolutl right
Becouse some people are insuring me that they have working EPG with same line
And no mather what app I dont have EPG
Just to correct myself a few posts ago i wrote that i manged to load epg from extreme iptv
Nope it loaded EPG from app included sources so it works only on ios devices
acording to some people here who reported working EPG
At least it doesnt work on android 6.0 and 7.0
I need feedback from android device users
Do you have EPG from Rapid
