I have this install on my kodi on firestick but it runs a little slow? Anyone know any settings that i change to make it run a little faster and maybe group the channels in lists, i.e sports, movies etc?
Thanks!
Thanks!
You can edit the playlist file with Notepad ++ and load it again in settings of pvr simple client.
I have a fire stick as well, could you tell me how you got it installed and running on your fire stick ?
thanks..
Please use SPMC on FireTV.
This is a optimized KODi Version for Android.
All Plugins for KODi Work with SPMC
Ok, i got Kodi 16.1 running and the finally Rapidiptv running after editing out the channel list...
my only issue is that the channel guide is not showing any channels.
it's only showing VIP, or unknown or unknown ### with various numbers....
any idea how to fix this ?
thanks..
has anyone seen the smart iptv app in the amazon store (not kodi) and got that to run the streams?
I test it and some channel not work
load the vlc player in store
and in the smart app press ok then press down and vlc player
its work fine
Has anyone been able to get a playlist to work on the smart iptv app in the amazon store On a firestick. Not kodi
I want to be able to upload the plays lists remotely. As my clients don't have the time or patience to do so
It doesn't take a playlist
Use the first option to upload your playlists, i assume you mean your .m3u files? if so it works fine but wont auto update when new channels are added.
LINK
The first box on the my list page, has
Upload your local IPTV playlist (5Mb file size limit)
written above it, enter mac address, browse to local playlist, press send.
Is there any tutorial on how to setup Amazon Fire TV with RapidIPTV?
