There is a setting with 4 alternatives. 1,2,3 or 4.
What does these settings do ?
Buffersize, memory allocations ?
Shouldn't there be an option like "depending on stream". Because all channels aren't running as equals ?
I tried the software.
The opening loading time is very long. And the epg support you must get the url for yourself.
The positive side is it can hold many streaming & Epg sources. The hardest thing is to know how to set the "default", "Auto", "Native", "Software", "Hardware" & "HW+".settings ?
I noticed if HW+ is too much the option is Hardware. But when are one using "Software" and "Native" setting ?
The software is getting better but sometimes it has the ability to crash. Hope there is a manual how to set things up. Some things are self explanatory while other
things are just not easy to understand.
Love the build-in player support.
Should be tweaked for an Android-TV support so it can be easily used with a remote.
Another positive part with the software. It doesn't have loads of pages of settings. However I wait for the next version to come out.
