What exactly do you mean by KO have you put in the whole epg link:
http://estiptv.site/epg/EU_guide.xml.gz
Did you resolve EPG issue on PPHi guys I have been using iptv smarters, kodi addon, and STB for a very long time, but the iptv smaters app ovr the last few weeks stopped draging the EPG in so now using Perfect Player, but i cant get anuy of teh EPG links to work from the dashboard or any links on here.
I sell another iptv and can get them working in PP no problem but that is for english and USA and canandain channels only, so is teh EPG down for rapid or iam doing something wrong, ben using PP a which to and its simple enough to setupbut i just cant get any of rapid epg to work in it.
Cheers
"Be more patient" epg is not working for a few month nowHello,
the Team is working on the EPG Update, please be a bit more patient, Thank you
EPG worked fine until last week on firetv stick 1st gen. Don't know what happend.Test
Change decoder to Hardware and tryHello all and thanks for adding me to the group. My first question I have is is there anyway to change the players on pp to nd or box? The reason I ask is my pp is starting to buffer more than usual and I very rarely had this issue only for a few channels with weak streams. I have android box 7.1 3gb 32gb. My settings are HW+ and 4. Or are there some settings that can enhance the playback because I really like perfect player. TIA
Do have the same problem with 4K movies on Perfect Player, some times it's the other way around, no picture but sound working.Hi all!
Can someone help me? I am using PP on Shield tv and I don´t have sound on 4k movies? Does someone know why and how I can fix it?
Do have the same problem with the sound in most 4K in movies section in Perfect Player.Hi all!
