We understand the issues and what happened since September 18. However a statement of what is going on, if it can be fixed or whatever would not hurt.
At least you will not be receiving endless email by people that do not read the news.
Thnks
Reactions: popers and avehome
Thnks
google xtream codes, then you get an idea whats happening... why is a statement needed when the info has been in the chat page for days...
Most of the channels I watch are fortunately not down. But I had to change my enigma2 settings from DVB (1) to gstreamer (4097) for it to work at all.
I haven't had any problems since February/March, so I'm still very happy. If now all channels work again, that would be wonderful.
Can anyone tell me if the streams on enigma2 in DVB mode 1 will work again? DVB is much faster when zapping (<1s) than gstreamer (>4-8s).
Reactions: Edvardsen
I have exactly the same problem. I also had to change my enigma2 settings from DVB (1) to IPTV (4097) for it to work.
I hope i can go back to use DVB (1) again, when all is fixed with Rapidiptv.
So i also wonder if enigma2 in DVB mode will work again?
Edvardsen
I had also the same experience.
However I noticed that since 3-4 days the channels are working also on DVB (1) again.
Cannot say if the same number of channels are working on both formats, but each one has his own favorite channels.
Using OpenATV 6.3 on my box.
Hi eltonbregu
I tried yesterday to switch over to DVB (1) but i nothing worked. :confused:
I'm also using OpenATV 6.3 on my Vu+ Solo 4K with the excellent plugin XE-AIO (All-in-one) from XEEV Playlist Editor aka Xtream Editor.
How do you get iptv on your enigma2 box?
I do not use any plugin. Just download you line as an enigma2 bouquet http://........................................type=dreambox&output=ts
Than you can import or edit it as per your own preference using dreamboxedit or e-channelizer
Ok.
I have also done it that way, but i liked the way it worked with the plugin from XEEV Playlist Editor aka Xtream Editor.
It should be almost the same, the plugin just add the bouquets to the box and you are good to go.
all these plugins were functioning using xtream-codes. Since september 18-th went off, so you cannot make use of such plugins for the time being
No this plugin have nothing to do with xtream-codes, they have pointed it out on their site.
Important note for new users and visitors!
XEEV Playlist Editor aka Xtream Editor has nothing to do with Xtream Codes Ltd. Our service is not streaming software!
So i'm good to go. :)
Reported this several times before:
Viasat motor (hd and sd) sweden
always has problems during F1.
tested on several devices, several isps.. same problem
It's seems merging complete but still some groups have issues. For example Swiss group was working well last week even rapid had problems. Now it's mostly down. Since this thursday some apps on my smart tv don't get rapid list. For example RSI La 2 HD CH is down but it was working even when the most of the channels were black.
I´ve been asked about Sony, &10, Sony Max, Star sports,, Zee tv and Zee cinema.. I´ve explained the situation to my clients but they say that these channels have been bad for months
