- Did you contact your reseller: Yes
- Diagnosis result: He couldn't help
- When the problem started: Saturday
- Which country: UK
- What is the exact issue: Channels are down, reseller refuses to help
- Which type of device: fiestick with iptvstreamers app
- What is the error code? (if there is any): no error given.
Reactions: community-tester
channel freezes ,repeats , RTL living FHD DE. Impossible to watch
The reseller was contacted: Yes and made also tickets
Which device: firetv stick, tivimate, iptv extreme pro, gse smart tv, smartphone tvimate iptv, gse smart tv, televizo
Have you tried 4G 5G VPN: Yes same probs, 3 different vpn's, dns changes etc.
Which country: germany
What is the problem: The channel freezes. the problem is mostly at the evening. in the night its fixed and next day the same. it also with other german channels like sky bundesliga 2
**** is it perhaps possible to finally eliminate the problem? ****
Did you contact your reseller (tag the reseller name with @ in front of his name):
- Dashboard Diagnosis result: all OK
- DNS Server setting: 8.8.8.8
- When the problem started: since a few weeks
- Which country: Netherlands
- What is the exact issue: Viaplay Xstra HD NL channels not working
- Which type of device (and app, if any): LG Smart IPTV M3U
- What is the error code (if any)? Viaplay Xstra HD NL channels NOT working
