V
Ive noticed some problems for about a week with polish channels. For last few days most of all polish channels are buffering for few seconds after few minutes of watching.
Im using Perfect Player on Android Box, where im able to see a bar which shows how much data has been loaded.
Before these problems has started, this bar was fully loaded all the time, but for last few days its loading up to the end, then its getting lower, like there would be some problems with receiving data. What i have to do is turn the channel back on, which is really annoying, as i have to do it every few minutes.
Im also watching UK channels where i havent noticed these problems, so it might be an issue with polish channels only.
Are polish and UK channels on different servers? If they are it might be some server issues.
Did anyone else message You with same problems recently?
What do you suggest to do to solve this? Unless some works have started already.
Thanks for any help.
