IPTV Community
Administrator
Jun 3, 2015
624
1,726
214
iptv.community
This thread is dedicated to technical question and installation tutorials regarding MAG 250.
Feel free to submit your questions and receive technical support from other community members.
n3w073
19
n3w073
Hi there,
I´m have some problems too with MAG device but If I understand right you don´t have to do anything for adding the channels to the MAG device. Everything will be in order as soon as you "add MAG device". If everything is valide the channels will automaticly upload.
abdelhh
Antwerp Belgium
abdelhh
Hi there,
So the portals in the mag i I leave it blank?
n3w073
19
n3w073
Reactions: abdelhh
Arben
20
Beni
hi. this portal does not work. "Your STB is blocked. Call the provider."
Whan can i do? i want to add channels from reseller account to my MAGbox?
thank you for your help!
n3w073
19
n3w073
Hi there Arben
you have to login in your reseller account and under "MAG DEVICES"
click on "add new MAG device"
register your MAG device by entering mac adress
follow instructions on web.
everything will be ok
klm Shqipe
Reactions: nuvola125 and Beny
adnanm
Adnanm
Got a message on my mag 250 "Your STB is blocked.
Call the provider.
anywone who knows how to fix it?
n3w073
19
n3w073
klm
Call the provider.
adnanm
Adnanm
klm
Thx for the quick answer
Flm
zingar
mag how to change the address in my edit user name notes is only by the number of mag can not change that.
mdmax
27
mdmax
Hello, i'm reseller.
I have my first client with mag system, he want to test the line...
I create a line with his MAC Adress in the resellers panel, what do i have to do next?
because i saw there is a portal: http://mag.rapidiptv.com/c/ (with rapidiptv adress)
Do i have to give this portal adress to my client to finish the configuration or what? what is the next step, pls???
