Hello, i'm reseller.
I have my first client with mag system, he want to test the line...
I create a line with his MAC Adress in the resellers panel, what do i have to do next?
because i saw there is a portal: http://mag.rapidiptv.com/c/ (with rapidiptv adress)
Do i have to give this portal adress to my client to finish the configuration or what? what is the next step, pls???
Nobody to answer?
Nobody to answer?
Check here http://rapidiptv.com/threads/mag-devices-stb-emulator-with-rapidiptv-installation-tutorial.1116/
Nobody to answer?
Thanks but with this, the client knows that i am a reseller from rapidiptv, rigth?
You can use this without rapidiptv logan
http://mag.clientportal.link/c/
it says: Your STB is not supported (maybe its because i don't have mag) its for my clients
i have to give this portal for my clients?
You have to setup the MAG yourself, don't give it to your clients
There is'nt a problem giving the portal address to clients, what if his client is in a different country ? its OK to let clients set up there own device.
Reactions: abdelhh
I've a iptv mag 250 but i can t record programms when i push F1.
Is it possible or not. Please give a solution if is it possible. Thanks
I second that. I think we should be able to at least recorde to an external HDD/USB an option which is available by default in the device but blocked by the server
Reactions: Dimitri86
It is possible but a bit long winded if you put your list onto a usb stick then put into your mag you then need to copy playlist off usb onto mag then watch through the onboard player you now can record
this works for mag 254 I only assume it works for 250
Hey
Im trying to record on mag portal but whenever i press on red button i receive an error "recording this channels is prohibited".
plus when i go to epg and try to record something in the future the record button (red) on screen is greyed out.
in a different thread someone did say he is able to record on mag ?
any idea ?
Most providers disable the recording feature.
The MAG 254 has the ability to record on an external device similar to a PVR but if the feature is disabled there's nothing you can do.
Why does @Rapid IPTV block it ? without having catch-up this is a killer feature.
With mag there is no pvr needed , just connect a usb drive and press on record.
Catch-up and recording paytv service is ilegal so if you ask me there never be something like that on rapid.
the method if i understand if using the native iptv player in mag internal portal (m3u,txt with channels) should be on USB drive for that.
then recording will work , its blocked via MAG external portal.
what about using SIPTV portal and load m3u to it ? recording is possible ?
