I can recorder a little bit but it stop with the error "pvr error: end of stream" at 2:20 +-
I have a SanDisk 64gb at fat32
Can someone help me please?
FactorHD
FactorHD
Put some faster card or usb key and try again.
Reactions: FactorHD
Seems a lot off people (including me) have this problem. Looks like the recoring bug was only partially solved.
yes i have search before here and i saw similar problems.
And someone can record without problems on mag250?
Guys from forum have recorded on pen drive but they had no problems.
Try to restart router, Mag box, reformat pen drive to fat32. Also try with buffering to 10 or 15.
Let me know
Reactions: FactorHD
I record from my Mag 254, onto a USB stick :) works like a charm!
Do you use a pen 3.0 or any one?
I am using a 2.0, I already did what was mentioned above, reformat the pen, restart the stb, change the buffering and nothing served, I did not try a USB stick because I do not have it. Could that be the problem?
We need to warn that it will affects uses of brandwitch and the connection will more slowly depending of connection quality
the connection more slowly can cause the stop recording with the error?
I really need to fix this problem
Thanks for the help
Try do not use internet too much or télévision, it uses much brandwitch
I tried everything, connected a external usb 3 ssd disk (so speed is not the problem). Formatted to FAT32 changed buffering to 10 and 15, but nothing helps. My internet is also not the problem because I have a stable 150mbps connection.
After 20 seconds the stream reloads and after 50 seconds I get the PVR error: end of stream message.
Please someone who managed to get it working help me.
Will it be possible to record "future" programs using the EPG ?
Hello
I run a few tests.
1. Inserted a usb drive usb 3, pressed the red button and it was able to start recording, I'm able to record for as long as i wanted but something is causing it to stop every 20 seconds or so, black screen for 1 or 2 seconds and back to recording (continuing).
2. I tried a faster memory, now with micro sd recorded for around 15 minutes, now black screen showing every 4 or 5 minutes.
As i see it its a matter of speed of memory...
I have time shifting off
Buffer set to off
Do you think it could help?
In addition, I'm not able to set future recordings from guide and event not to schedule start and end time.
I wanted to activate my subscription on a mag250
I followed the instructions but when im in the setting menu and i go to server.i only see the choice between general-more.
I cant see the option portals.
Does this sounds familiar to anyone or does somebody know what i should do next?
You would help me out a lot.
I paid for a year subscription but i cant use it yet.
Try to reset your mag
Dear,
Can someone explain to me why a mag250 turned off at night and the next day needs to be restarted in order for it to work properly.
It works with the portal ...
