When i use 3,5mm audio out on my MAG250 it is a interference noise. A loud noise, but i can even hear the Aodio out from the TVprograms.
I use:
Initial Volume = , 100
Audio output mode = Stereo
Operating Mode = Line Mode
Spdif Mode = Bitstream
HDMI mode = PCM
It sounds like a electromagnetic interference noise.
I have tryed 2 different 3,5mm into RCA in to my receiver. And hearphones with the same noise.
Any suggestions?
Sound is ok over HDMI to TV.
But i want to connect headphones and my receiver without thaat noise.
Solution! This works for me. Go to inner Portal --- Settings --- here ist the place to specify where to load after startup ---- there are three options
1, Home Media
2, IPTV Channels
3, Main Menue
Select 3, Main Menue and the issue should be solved...
I have dozens and I don't have a single issue with them :D
Furthermore, clients now use only the TV Remote as they are CEC complaint :P - As long as they are genuine
Mag box with the mag text above is fake. Mag box with the picture of the earth is the good one.
I recently bought a Mag250 without being a technical genious!!!!
The seller didn`t send me any codes fo installing this :smilingimp::rage: machine,
and will NOT answer my messages.
I`ve watched several clips on YouTube, but doesn´t get it anyway!
I live in Sweden and need info on how to get started.
Can anyone PLEASE help me??!! I´m lost in space on this one!
hello
Watch PM
Did you read this steps ?
https://iptv.community/threads/turtorial-magbox.6664/
And wich codes do you mean ? only codes on the box are the ones for the adult channels
Has anyone found a way to solve this problem? The same problem is happening to my box and have no idea how to solve it
I´ve tried to set def. settings on a Mag 250 box but I couldnt save and exit the bios because when the box is restarting its just get to de tftp Load and sometime dhcp and nothing happens.
When I try to change boot mode to nand or Nand 2 its the same if I want to set def. settings but I can just start the box with Nand boot mode and get to inner portal. But now when I want to enter the Server portals the line are grey and I cant put the portal adress or anything.
Please help me.
on start up SOFTWARE AUTOUPDATE.
CURRENT VERSION : 0
DESCRIPTION : FACTORY IMAGE
DATE: INVALID DATE INVALID DATE
NEW VERSION : 218
DESCRIPTION : 0.2.18-r19-250
DATE : MON JUN 12 2017
UPDATE STATUS : WRONG SIGNATURE.
when i go into server only has GENERAL no portal n no MORE.
HELP PLEASE
