efter uppgradin mag 250 with new soft from december 19 is dead end canr start- have enybody same solution pleas?
Mag box with the mag text above is fake. Mag box with the picture of the earth is the good one.
What if it looks like this, original or clone?
http://i65.tinypic.com/2d0ykiu.jpg
same problem here, ordered from aliexpress (mag reseller, has "original" hologram labeln on box !!!) 5 peaces, all of theme dead after newest firmware from infomir
When the box loads, I see a bunch of garbled characters instead of tv channel list, looks like computer programming language. I diagnose the line via the dashboard and I get the message "the line has an issue with channel list 216" clicking resolve request does not fix the problem. Any ideas?
Hi guys
so i get this error wrong signature that i cant fix after trying everything i can found on the net
Ive done the df setting reset
tried different firmwares to install with the same error Both through the portal and the bios, although when in bios it doesnt find the files on the usb, i suspect it doesnt read the usb when in bios
i got subscription left but providor got closed down so i did a reset
did he put some restrictions in that i cant unlock?
And it says
current version 0
descriptin: factory image
date: invalid date
when trying to download an update through their sites it finds the new version but wont download it
at first i thought maybe they sold me a fake but thats not the case from what ive seen
Trying for 2 days now
help :(
After a few hours trying i got multicast to at least do something but it gets stuck on reception of an image is started
goes on for about 20 min until mc is crashing
Hi,I have problem with mag 25x recivers,where recivers goes off(JUST STOPPED) in some times after 30 minutes,sometimes 1,2,3 hours..and they need to plug off power cable and turn it on again..and process restarting again after some times??Also I cant update image anymore on mag 250,worked perfectly for years but,problems starterd before 10 days..any solutions???Thanks
Reactions: Mikeios
Reason your boxes are dead is because the latest software was a clone killer
Wen there is multi sub´s i have problems to find SWE sub´s, it´s like i have to small screen. How do i show all sub´s?
Hello, i have the possibility to reflash the mag250 from deat to life
Triton
Reactions: retro
