Madz
20
iptvboy.com
wissamyamout
Hi, one of my clients tried to factory reset his box and it says wrong digital signature .. and something about image what should he do?
I fixed the wrong digital signature by resetting it from the Upgrade tools
- Unplug the box
- Press menu on the remote then plugin when holding the menu button until the blue screen comes with options
- Go into upgrade tools
- set / reset Operator's key
- have an image ready in usb
- then upgrade software by usb
Madz
20
iptvboy.com
wissamyamout
Does anyone has a mag256 older firmware by any chance? the latest firmware resulted to having no sound I need to downgrade but cant find any old versions online.
Rasim1970
OK, don't worry, it's no problem :)
Just go to embedded portal, then Settings -> System settings -> Device info. Please send me photo of this screen (of course cover MAC address and serial number ;) ).
I have the some probleem. Please help
Vendor is teletec
Hardware version is 2.6-IB-00
Active bank is bank 1
Image version is 218
Image discription is smartbox_v1254
Image date is wed May 4 10:01:46 CDT 2016
RootFS version is 0.2.18-r14 254 fri Jan 15 15:32:00 EET 2016
Martinccv
I have 349w3 and it is working with sub. Problem is that sometimes it is having problems when loading the portal. Just hangs while loading and it is very annoying. And I also only can power off it manually, not with the remote control. Any idea?
Vehbija
Aug 29, 2017
22
xnuiptv.com
Vehbija
1/Settings
2/Go to the inner portal
3/Off
Work 100% ;)
wwe
64
William Elders
Did you find an answer to this as I am getting this error on 2 clients both in the Uk using mag boxes and different internet providers
Cherub
Hi, I have a mag box 254 and every iptv provider I've used doesn't allow me to use the record and reminder functions. Does anyone know of a provider that'll allow them to work? Also I like the black stalker portal theme, but most providers have blue, how do I change it? Thanks ☺
Camdtv
i want the blank more modern stalker theme too, its a shame they dont get it :(
john3690
I have a mag254 registered with an iptv provider, I lost the portal settings and can't get a reply for help, how can Inde -register the box to sign up with another. John
Bruce Hand
esso5000
Hello just change your MAC address last 2 numbers and re register with a different provider. It is presently locked to the previous provider
