Nepose
21
Okay, no problem :)
Download STBEmu (Free) app from Google Play store to your phone. Then click "Configure" and choose profile. Put your STB's MAC, portal address and model at settings of your profile. Then save them, go back to main menu of emulator and click "Reload portal".
Emulator is an app for phone which emulates STB. You can check whether it works on your phone "as MAG box".
beaversweede
I have a few issues with my mag256.
First of all I can't record or pause on any channels in the portal.
Second is that it's not possible to sort the channels in the favorite list and I can't get the EPG to show only my favorite channels.
Nepose
21
Hi mate :)
Doesn't your provider block possibility of recording? Some operators do it.
And you use Smart Launcher skin or Classic?
iptvfeo
davdav112
Hi!
I cuold`t make work mag349/350w3 with rapidsswiss .It`s said not support . Any suggestion ?????
7,035
try to install STB Emulator or Smart IPTV app or KODI on that box.
iptvfeo
davdav112
Hello!
This message means that your IPTV provider uses Middleware, which is not supported by your box.
On this issue, you should contact the service provider and discuss it with him if your IPTV service provider cannot solve the problem on your own, they can contact us to solve the problem support infomir
DeniD
Shower
Any one can help me?
I have after loading Portal a black screen.
itsmemari0
22
20
Same here
i cant load the portal. i cant even see the blue load progress bar. i only see a black screen.
pls help
gEck0
40
47
I have the same problem, after the selection menu, the picture remains black
DeniD
Shower
I'm a reseller and have the same problem!
This problem is a host problem.
Infomir released new firmware and all boxes need to be updated. Use exactly portal that you give him and change DNS to 8.8.8.8 or 1.1.1.1 or 1.0.0.1
DNS on MAG box change to 8.8.8.8 or 1.1.1.1 or 1.0.0.1 > System settings > Network > Wired (Ethernet) > Auto (DHCP), manual DNS
DeniD
Shower
Don't work I have the same problem
Vehbija
Aug 29, 2017
22
xnuiptv.com
Vehbija
Same Here. Portal still not working on my mag254
I recommend you take 349 / w3 or 352 4K operating 100% verified. Mag 254 is already outdated with 256 mb ram and it's very bad on our update because it does not have a powerful processor, all the newer ones have a 1Gb ram or more. So, I recommend you to buy New Mag!
Svintoman
Trusted & Verified
79
130
33
svinto.xdns.pro
svintotv@protonmail.com
I got a Mag 256 and it works fine but sometimes when I start it up there is no sound.
I need to unplugg it and restart it to get the sound back.
Anyone know why and how to solve it?
