Hello All,
My first post so I hope I have done it right!
I am running IPTV on an android app (IPTV Extreme) on an Android TV box.
When I connect to my VPN client which is installed on the Android TV box it stops all the channels from being displayed. When I disconnect they come right back on.
I have tried different servers and locations and cannot get the VPN and IPTV to work together,
Speaking to PIA they have said that my best bet would be to install the VPN on the router itself, this would mean buying another router as mine doesn't support this. I'm happy to do this if it will fix it though.
Does anyone use PIA with IPTV and if so do/did you have any connection issues?
Am I doing something wrong?
TIA,
Danny.
Vpns are not supported.
Before anwsering know the facts
VPN has to be with a dedicated VPN.
i recommend all mine clients to use Torguard, Nordvpn or libertyshield
Thank you,
That would have been idea have i have not paid for a new 2 year subscription only a few weeks ago :(
My VPN provider has confirmed they do not provide Dedicated IP's
Dan
Hi Guys,
at the moment I'm trying out Live Channels/TVirl and like the look and feel of the app but the one thing that I can't figure out is when I load the M3U list all channels will load but they are not been sorted out in maps,so if I want to switch from a country I need to scroll like 1000 channels:astonished: and I know I can setup favorites but that's not how I like it.Does someone know how to fix this??
I have a mag 256 which I have had to reset to factory settings. Does anyone know how to re set it to my providers general NTP server and portal.
the NTP Text box is blank but the portal 1 URL text box shows as
http://bit.ly/2qVqs.
l originally purchased it from a martyn@iptv.now.tv but have had no response to my emails.
Hi David,
As long as you can edit those fields just input the info provided from your reseller.
only if it's a private IP and not a shared IP...
If it's around 10 dollars a month it's mostly private and good.
Hey Guys,
i need help. Is it possible to use 2 different Lines at the same IP Adress or will be blocked?
Greez
Chris
Hey Guys,
Greez
Chris
yes, you can use 2 different lines at the same time with the same IP and it is not blocking your IP.
Reactions: rmallia
I posted a DVR question aboout IPTV services and it was deleted.
I didn't know this forum was only for Rapid. Now I know.
So does Rapid IPTV have DVR option?
If not, will DVR ever be available? or anyways to record tv shows and watch later?
Question is NOT about PVR in Kodi, or stand alone DVR unit.
Hi. I have a striker t503 box and woner if i its possible to use this with iptv?
i have tested it on latest linux mint 64bit and it works good.
FreddyK, which linux are you using?
Hi, there is a update online
testet it with opensuse gnome 3.20.2
i startet it with:
droping xmlgrabplus binary onto terminal
click on terminal and hit enter
