Hey all,
I've downloaded SIPTV on my samsung tv(2016 modell) and I've got the following problem:
If I upload a playlist via url SIPTV keeps refreshing as soon as the primary channel list pops up.
I can avoid this if i select only one category in the bouquet list, but thats definitly not what I want. (guess categories or to many channels are causing the problem)
If i dump the list and upload it as file, the problem is gone.
So i tried to select 4 categories (but disabled categories on the SIPTV web panel), exported the list from the url and uploaded it manually(as file) to SIPTV and it worked fine.
Does anyone else have the same problem and if I can't fix that, is there any chance to get an up2date list (because I don't want to dump the list and upload it again, every x hours) and also to use groups? It's very annoing, since I wan't to have around 5 different categories, if theyre not grouped.
