Hi guys,
I have a small problem and maybe some of you could know the solution. Before couple of months I started to use SmartIPTV app on my Samsung Smart TV. Everything was perfect with the app in the beginning and then all of a sudden some notification "Live" started to constantly appear in the right bottom corner of my TV. Now it's getting really annoying. There is not even an option in the "Settings" to somehow turn it off! And this keeps blinking and blinking. Did anyone have a similar problem? I don't know what to do.
P.S. TV is connected via Wi-Fi.
Any suggestions, maybe?
Thanks in advance!
Luka
my father have The same problem. He had bough new Samsung q70 tv 2023 model and he have 1000 mbit Ethernet but almost all Channel dont work..
Hi guys,
I need to buy a new TV as my 10-year old Samsung died.
I would like to buy again a Samsung one but I want to make sure I can use Smart IpTV app. I know there were some restrictions and it wasn't published on the app market (so need to perform a manual install). Could someone confirm there is no restriction with the new Samsung models?
Gentlemen, I'm trying to install Smarters IPTV on my Samsung Smart TV. At the Google Play Store when I click Install, it says no device found. Can you please tell me what steps I have to do to be able to download and install this App? Thanks in advance for any and all advice offered. Is my Smart TV not a device? I'm completely new to IPTV and need some guidance to get started. I can't even begin, if I can't download the App. I don't want to use a laptop or FireStick, I'd prefer just using my Smart TV, is that not an option?
Rob,
Cancel this request for Support, not that anyone answered me anyways. I could not download from the Google Play Store, but I was able to download through a Samsung Account. I do have it installed now, and testing everything. My goal is to ditch my cable Provider.........let's hope it has all the channels I want and need.
hi. I have issues to use external EPG on the Samsung smart tv app. It is like it is ignored and it uses its own app epg.
I don't have this issue with the siptv installed in the firestick.
I have tried different options when adding the playlist.
Does anybody has a solution to this issue?
Samsung Smart TVs often face cache memory issues, likely due to a large EPG file. To fix this, reduce the bouquet list to 2-3 countries and use the XMLTV EPG link generated from the m3u file. This should reduce data, allowing you to check if the EPG loads correctly and resolves the issue.
Thanks for your suggestion.
I got in touch with the developer that was very supportive. Eventually the issue was due to an not correct mapping of the epg. It seems that he made an adjustment in the way some epg are read and now all is working fine.
