Hello I use newnigma2 with dm7080 box. Whom I would like to see a sender I get a green screen on what I do wrong on dm 800 and 800 no problems
Send a picture and let me see in pm
@Cykelkalle thank you work finei have the plugins installed on my vu plus duo 2 but the skin is small can you me send the skin thank you
I have a Dreambox 7080 HD with Merlin4 OE 2.5. I have installed the plugin and can see it in the menu and start. When I choose a channel I get a green screen.
Any solution for that?
pls add skin here, because lots of users have the same problemcan someone send me the correct skin please.
thanks in advance
thanks in advance
Enigma 2.0 scripthi i am using openvix E2 image which script would i use in the client portal for this to work please
wwe
So, I just started, i made the list bigger, the icons smaller, and im gonna change the EPG information.
http://imgur.com/a/VGVag
I downloaded the one on first post, followed instruction and pasted my login and restarted my box (not just gui) and it works fine! VU+ solo2 openvixHello
Since Update on on Client portal links, i cant seem to get this plugin working again...
Anyone have some info or version that is working now?
Is it possible to favorite channels with this plugin??
