neggs
Thanks Joniale. I've spotted my silly mistake! I was coping the whole folder structure directly into the /usr/lib/enigma2/python/Plugins/Extensions instead of root (with corrected capital letters).
Cheers dude!
Beny
171
49
Switzerland
stariptv
Anyone else have Problems on Some E2 Devices?
On the most it works, but some doesnt work. I cant install it. The most are VU Boxes?
Bartje
bartje
Tried this on PLI image but I am getting this error
Playlist error
no element found line 1, column 0
url:
http://clientportal.link:8080:enigma2.pho
At first I had my password wrong but changed it.
Think I am almost there, first time I opened the app got a green restart screen.
Bartje
bartje
I did a complete reinstall of the vu uno en reinstalled the app.
Now it works. Looks good.
One question, if I am in for example the belgium group how can I go back to see all the groups?
I can use the red button but then I go back to the main menu seeing live tv and vod.
On the MAG I can press left for that option.
Barbapapa
i have a DM900 UHD with OE2.5.
unfortunally that xmlEPG does'nt work on my device.
Have someone the same box? maby with a solution?
greets
Eastern
I get a free trial and want to use this plugin. VOD works great but no channel working.
Has anybody an idea why I have Black Screen on any tv channel?
I use Vu+ Solo2 and VTI Image
Franqie
Here to help you become official Reseller!
Franqie
do you have a personalized trial? with your own name (Eastern) in the Username field?
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Try install other image for your device, like openpli
Eastern
Yes the username is in my field its personalized
whats the problem with vti? I have no experience with open pli.
adab79
Ludwigshafen Germany
adab79
I have vu zero and cloudibox3 and i install on both the plugin and itry almost all image and must say the best image is open pli. It work really very good and stable.
Just have a question if i can make the plugin eorking directly by starting (with less clicks)
Niceguy
35
30
SunnySr
Have a small problem with the plugin.
Had this plugin with a trial line installed for an intrested customer.
Customer has now subscribed and I gave him a new account with secure password...
But the User and Password in the plugin are still those from the trial line..
I see no normal way to remove this plugin? HOWTO?
Or
Can I change the password used in the plugin?
TIA
Carel
Works for me ok on Gigablue Quad HD plus with OPENATV.
Can't find the option to switch the subtitles by VOD multi subtitle?
BR
trebiasgreg
12
Or
TIA
Just edit using FTP and NOTEPAD the file 'xc_e2_plugin.xml' in /etc/enigma2 and change with new user and password.
Niceguy
35
30
SunnySr
OK have changed the user and pass and that works
Now I have one question...
Why do the streams play better in this plugin then when I generate a bouquet file and use them in the user bouquets? Do they use different players?
Also this has some epg but the Bouquet stream does not
The EPG is out of sync though, Have a different timezone here...
How must I change the bouquet stream to include epg?:
#SERVICE 1:0:1:0:0:0:0:0:0:0:http%3a//clientportal.link%3a8080/live/User/Pass/1629.ts
#DESCRIPTION: ZDF DE
Another Question is Now I get all channels; is it possible to edit the offering into just the channels I want to offer to my customer? Also the customer is NOT intrested in about 90% of the channels offered...
Thanks in advance!
ovinovi
Hi thx for the plug ind but how to start automatic the plug ind when my vu plus solo2 reboots , and how to make to the plug ind or Vuplus to remember with audio track and with subs track on a channel .
If i do change on channel 1 the audio to tarck 2 and the subs to track 2 the is working but if i change to another channel when i come back to the channel where i was before then the audio and the subs are back to the default how i get that save?
regards
Senco
Hi, very nice plugin!
I am also wondering if there is any way to make the interface and user experience a little better? Like showing larger (more visible) channellist? Also go back from a category to another?
When pressing down button while watching channel nothing happens? Only when pressing up button it shows channel list not when pressing down...
When I want to close the channellist I am very used of pressing the exit button, but in this case it asks me to exit the plugin.
The more like dreambox user experience (the whole concent, changing channels, change categories etc.) the better...
Sorry for asking to much, but I think these things would make this plugin PERFECT! And I am sure many others thinks the same! Thanks!
