hi folks, been trying to get xc pluging to work for last few days
first i was using the zip file from dreambox4u.com, but i was getting "play list error" fault coming up
just tried the zip from page one,
i screen i get shows 2 blue boxes and a red home button, but no playlist
when i press any button on remote it sends the box in to restart
using a vu+ solo2 (origanal not clone) openblackhole image
i can view IPTV on this box with Tsmedia and an m3u file but it s buffering a lot of the time
guy i got the "line/service" from says to use xc plugin, but just can't get it working
folders on Vu+ show
usr/lib/enigma2/python/Plugins/Extensions/XCplugin
etc/enigma2/xc_e2_plugin.xml
guy sent me an xml file with his details on so i edited the origanal xc_e2_plugin.xml file so it shows just the details he sent me
(when i compare the origanal with his only differences are password name and web address)
anyone give me a clue to what could be wrong
folders on Vu+ show
.XML in etc /enigma2, you need to edit the URL to that of provider and change user and pass in that xml
thanks[/QUOTE]
.XML in etc /enigma2, you need to edit the URL to that of provider and change user and pass in that xml[/QUOTE]
as i said in post I've edited the xml file
or should the fie id be XML
Hi m8
Remove the file you edited and try the one your supplier sent you. I would use filezilla to remove file.
Hi.
I am trying to use this plugin on a vu+ solo running blackhole. The plugin just crashes the box everytime.
edit: It now loads the plugin and I can see all channels in the list. However when I click on one I just get a blank screen and the stream never plays.
Hi.
I had the same problem. I flashed openpli on my vu+ solo and never looked back :)
OpenPli 4
