Yes that can only be the old stick because because with the new does not work!
By the way, with perfect player always choose hardware encoder from ...
Has here really else no idea what one can do there?
Can not imagine that no one would use Amazon Stick 2?
i work with kodi but for iptv i use perfect player because the iptv lists hanging on kodi
amazon stick gen 2 only works with kodi or vavoo god with iptv because smart and perfect player is fhd very bad because pixel salad plaese use kodi whith pvr simple iptv client or vavoo for iptv
i have an account on a fire stick
Using Smart iptv and it’s not working very well I want to remove the account from Siptv and put it on a Mag box how do I delete the account from siptv so Smart Iptv dies not work
Just ask youre reseller to ad the mac adres on the line:
and go to http://sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/mylist/
and enter youremac from siptv in the delete list box
I found some cases with issue like pixel salad in SMART IPTV. Does anyboyd found solution for this issue? Maybe older version of SMART IPTV 'll works?
I tryed already on KODI and it's works, but then I have issue with EPG so again unsuccess story.
Any ideas how to fix?
Rgds,
Piotr
any solution for this issue?
Maybe older version Smart IPTV?
dont think so, having this problem since long time....
by the way, these days amazon released another generation of fire tv stick... i hope that new generation will fix the pixel salad...
hey guys, how sven müller said, works with kodi and vavoo, and i mean vavoo has a better performance but you can try both out
Yes I have same problem with my amzon firestick I believe its only for newer model or software not sure
My dad has al older firestick still with alexa and no pixelating at all...
Acctualy it helped but only on HD TV, on 4k TV is better but strange artefacts still appear.
Even on HD TV is not perfect. Comb effect is noticable at fast sceens.
