You can add your list to Smartip or Perfect Player and select for the Play VLC.Hello,
how do you put the list in vlc?
to see VOD
Thank
to see VOD
Thank
Hello today i recieved the new Amazon fire tv Stick
Then i installed Smartiptv and Perfect Player both apps was having really bad transcoding issues
Then i installed the Newest Kodi 17.1 and there it is Perfect!
So for every user that wants to watch on the new Amazon Fire TV Stick install Kodi 17.1 i know is crazy because normaly i would say Amazon devices = Perfect Player but the new Stick is so much Bullshit that you HAVE to use Kodi
I cant install rapid with perfect player, everytine i put the link is not updating and when I hit the update thing is not doing nothing, gave up, smart iptv is much better for meHello,
I have exactly the same problems I do not get it to run on the new amazon sticks ...
Perfect player does not run, smart iptv is not synonymous, and with Kodi it crashes every few minutes ... have a bunch of customers with new sticks and can do nothing ...
Has someone already a solution?
Thank
Nop sorry, till now not, exactly the same what you write
I use perfect player with hardware encoder. Works well..
