Hello Mark,I have a constant issue with all channels: the stream plays great for like 30 minutes or an hour, and then suddenly the stream completely stops, as if I had closed a video file. I use my PC (M3U playlist) to watch the streams, usually using VLC or MPC-HC (in both cases the issue happens in the same way).
BeIN Sports 7, 8, 9, 10 FHD ARAB all have a low FPS and are no longer FHD!
Fox Sport 3, 4, 5, 6 HD and FHD Netherlands/Holland have the same problem, low FPS, not FHD
Still no picture on ViasatExplore SE and ViasatNature SECountry: Sweden
Device: ALL
Channels Name: Viasat Explore SE, Viasat History SE, Viasat Nature SE
Problems: Viasat Explore SE, Glitching and frezing and No swedish subtitle
Viasat Nature SE, No picture at all
By reporting the issues via your Dashboard, your cases will be solved way quicker. Please submit a ticket.Country: Sweden
Channel Name: MTV SE
Problems: norwegian subtitles instead of swedish. Not sure if possible to report this type of problem in dashboard or not.
