If a channel is Down, No Sound, No Picture or Wrong Channel
please report it directly from your Dashboard "Channels" section (eg http://prntscr.com/kku652).
It's the right & fastest way to get it sorted!
The Channel does not show up at channel report section - then submit pls a ticket directly from your DB.
Thank you.
CMORE Fotboll HD SE
Country: Sweden
Issue "Chanel lagging and freezing constantly. Restarts again and again”.
CMORE LIVE HD
Country: Sweden
CMORE FOTBOLL HD
Country: Sweden
Issue "Channel looping same sequence all the time"
CMORE LIVE 2 HD
Country: Sweden
Issue "Not showing game"
Works like shit right now
Guys, I am using a TVIP 605 box. Since around two weeks back now (about same time as there was a firmware update), changing channels takes "forever". When I say forever, it can take anywhere from 2 seconds, to five minutes or more. I have contacted the factory, they suspected missing tags in the M3U, but also supplied me with a beta firmware - wich worked better for two days, then it is back to same as the official firmware. It takes forever to change channels.
What to do? This is terribly frustrating.
BTW: I am on 1GBPS fiber, so no problem with the Internet connection.
CT Sport CZ - freezing
TELKA CZ = new name of the channel is "Nova Gold"
SMICHOV = new name of the channel is "Nova 2"
is it possible to make the channels:
Planet Sport 1-3 Croatia and
Sky Sports channels UK more fluent? Like 50fps?
Thanks!
CT 24 CZ = sometimes working, sometimes in loop.
CT Sport = same problem
CT 2 HD CZ = switching always from FHD to SD, sometimes in loop.
Eurosport 1 and 2 FHD CZ = down
As you found some good and stable Czech channels ressources recently, can you fix these problems?
Canal + Discovery PL
Channel has been renamed to Canal+ Dokument since 1st of July,
Please also adjust EPG for that channel,
Country: Sweden
Device: ALL
Channels Name: Viasat Explore SE, Viasat History SE, Viasat Nature SE
Problems: Doesn´t work!! since a couple of days
Eleven sports Portugal channels 1-6 always change their resolution (sometimes fhd and good fps, sometimes bad fps, sometimes bad sd)
Same problem for these channels:
Canal+ Sport 2 Poland
BeIN Sport 1-3 FHD France (and the Max channels aswell)
please find a stable source for these channels!
Reactions: aflf and Artan92
