I made a ticket on there homepage and got this answer.
"LG OS do not support any of this functions. How ever we are waiting for LG developers to give us a solution for it
Kind regards,
Smart-STB support team. "
RED - Select audio track in stream/video (webOS); Toggle DVB input (Netcast TVs)
Changing audio language
If you have webOS 3.0 TV, you can select audio track and turn subtitles on/off using red/green buttons. On webOS 2.0 it's only possible to turn subtitles on/off.
For older LG Smart TVs, the audio track can only be "forced" in the playlist (for streams only, not VOD!). Otherwise, stream audio language is automatically selected based on the Audio Language Settings (1st Audio) on your LG Smart TV (see picture below).
If you have webOS TV, you will need to set webOS Video Mode to NC MPEG or NC Auto in App's Settings for this "forced" function to work. This function only works for streams that it supports (usually HTTP only, not m3u8).
Source: https://siptv.app/howto/lg/
For the VOD Multi-Subtitles, there is no way to change the language of the subtitles?
I can put them on/off but just to the first language.
I have a LG OLED with webOS 04.70.85.
Could somebody help me?
Thanks a lot
You have problem with all movies in subtitles group or
Yes, all Multi-subtitles, I can just switch on-off but never change the language.
Since yesterday I have another problem with Smart IPTV but I will make another topic for this.
Thank you Rusax. I can put on/off subtitles but not changing language of subtitles.
I have a new LG OLED TV and it's OS 3.0 or more
Thank you, but I use Smart IPTV and don't have this kind of options like in a video.
Is there any fix for this yet? Have same problem on Smart IPTV on LG with Web OS 3.5
My client already use a mag device, can he also use smart stb? Not at the same time.
I having some trouble with registar his mac afres, this can register only once?
is your laylist valid
we have same problem , our list is valid and work on computer , but it is deleted automatically,
I will be happy if you could help me to resove this problem.
Best Regrds,
