Jems
Jems
Verified & Trusted reseller
53
Jems
hi mates
I have 2 clients that have some smaller issues with SIPTV App on LG Smart TV.
What I know right now is that both have an LG TV with low memory. So I had to short the list. It works now but they have regulary "black screens" and then they have to switch channel forward and backward in order that it works again... of course that's a bit boring.
Can someone tell me if that's still related with the memory and I maybe have to shorten the bouquet list even more?
Myself I have Samsung TV and all other clients have aswell Samsung or LG (bit better LG with enough memory) and it works without any issues. So the problem cannot be the source and it has to be the TV? Or at least the internet provider maybe?
Any ideas?
Thanks in advance and cheers.
Hello, i have a lg with low memory but the only problem i have seen with low memory was not loading playlist. Did you try to save online the playlist when you uploaded it?
droelfmalbumst
droelfmalbumst
Active Member
Jan 7, 2019
118
46
droelfmalbumst
yes also tried with saving online..
maybe it's related to the internet provider? both clients with the same problem have sunrise... with swisscom no issues at all...
droelfmalbumst
droelfmalbumst
Active Member
Jan 7, 2019
118
46
droelfmalbumst
thx will try that!!
droelfmalbumst
droelfmalbumst
Active Member
Jan 7, 2019
118
46
droelfmalbumst
just a feedback to my issue posted here...
Client had problems that screen got regulary black and he had to switch channel in order that it worked again.
I changed his DNS on the TV settings to 8.8.8.8 and he tested it yesterday the whole afternoon and evening... I got feedback that it works perfect now.
So I guess DNS change helps out... I have 2 clients both with LG and both with same internet provider and both with LG TV with low memory... and they're the only clients with this issue. I will do the same with the second client in order that his one works perfect too...
This as information for other people here that might have same issue.
Reactions: Sandrito and Jems
B
BigYin99
I am having an issue with smart iptv app on my LG tv. It was working fine for months and not when I load it up I get a message saying
‘Check playlist nr 1 url’ and the EPG doesn’t load. 1st couple of times I reloaded the app and it was ok, now nothing at all. Anyone got advice what to do to solve the issue?
Jems
Jems
53
Jems
Try to remove some channels
S
Skol
We had exactly the same issue on two different LGs. Two solutions : -
(1) Select "Reload" from the Smart App setup screen and, depending on your BB speed, the all channels horizontal view will soon show. Of course, if you exclude some of the groups you never use (through Dashboard), then the reload time will be speeded up.
(2) If that doesn't work (or stops working) go to SIPTV and delete your line and, then, re-input the line. Then repeat (1).
Good luck.
droelfmalbumst
droelfmalbumst
Active Member
Jan 7, 2019
118
46
droelfmalbumst
your tv memory is full... you have to shorten your playlist otherwise no chance
C
corba
I have Lg older model lm, how to turn on/off sub on multi vod?
F
Filipe74
Anybodys knows where SmartIPTV on LG gets it's EPG? I didn't configurate anything and EPG appears in many channles, so I would like to copy that URL to my Android box, if possible.
Thanks.
droelfmalbumst
droelfmalbumst
Active Member
Jan 7, 2019
118
46
droelfmalbumst
it takes EPG from the m3u...
K
kvaman
Is it possible to install VLC on LG Oled65E8PLA
J
Justwatch
Earnmonitor
No only smart Iptv or smart stb on Samsung and lg smart tvs
M
Maceek6
Have someone info about update SIPTV? I have multi-sub VOD and i can't choose and change subtitles.. When i use VLC on PC i have 20 lines to choose :/
droelfmalbumst
droelfmalbumst
Active Member
Jan 7, 2019
118
46
droelfmalbumst
not possible with SIPTV... use other app or buy a box :)
W
wleszczynski
Hi All,
I am using SmartIPTV on my LG OLED.
All seems to be fine, however I am missing EPG on some channels from Live POLAND group - BBC CBeebies (2982), BBC First FHD (2984), Canal+ channels (2993-2997 & 2999), Cinemax HD (3002), and others (3007, 3020, 3022, 3023, 3025, 3036, 3042, 3054, 3057, 3058, 3061, 3062, 3063, 3064, 3066, 3067, 3068, 3071, 3073, 3074, 3082, 3090, 3097-3102, 3106, 3114, 3118, 3134, 3149, 3151-3156, 3158, 3161, 3116, 3166).
@Sense confirmed EPG is available for majority of these channels so I guess it is an issue with SIPTV application not fetching complete info from the m3u link.
Does any of you have an idea how I can get that fixed?
Thanks,
Wojtek
Similar threads
