okay i dont have webOS at all..
but still dont understand..why cant i change the subs when i want to watch a movie in the group/menu
VOD multi subs? english audio is fine but would be great if the sub also was working
one friend of mine keeps saying that when in some channels can't remove the audio description.
For example, just now, he told me Cartoon network UK package has audio description on and can't or doesn't know how to take it off.
Anyone knows ?
http://sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/howto/lg/
Reactions: riboy
Sure on some lg tvs you can't change audio stream unless there has been a recent update
im trying tp get subs working on my smart tv but when i push the red button to change it i get UND can some one help me ?
Note: in VLC i can change the subs
Reactions: Skol
Me too!
Smart IPTV + VLC on my Fire TV box connected to my LG WebOs 3.3.1 TV works fine, but with Smart directly on my TV, the Red & Green btns do not enable a choice of languages / subtitles in multi-sub VOD using the LG controller.
Any solution?
Reactions: timetravelprimer
Hey
Is subs possible at lg smarttv at rapid?
Both in vods and channels?
If the channel or VOD you're watching carries them, then yes.
press and hold red button. Select the relevant subtitle entry if one is shown. If there isn't one then that channel doesn't have them
Is this possible with smart IP-TV app?
Channel list disappears every time I turn off TV, then I need to uploud the channel list again.
Tv Modell: LG 55LM640T
So ask Sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN ******* whats goiing on...
Not a server issue...
