No all channels have the same audio properties.
All I can say is, that if it works fine on other devices, and other people generally has no problems with those channels, they way you describe it.
Then surely it must be something with your TV settings?
Maybe you can open the offending channels in VLC, so you can see the codec info for them, compare that to channels with no issues.
That could be a way of getting a bit wiser as to the root cause here
