The test must be false.Go to browser, and go to fast.comhi
thats the case on my box, too. so i gave up trying
It depends on the device, if support WiFi ac or nThe test must be false.Go to browser, and go to fast.comhi
I just get 2,4 Mbit over the website.
On my Phone/Laptop i get 30-40 Mbits. All my Channels works perfect (also Full HD). So the speed can't be correct.
Hello,GhostPhantom, Hekuran,
hello friends
thanks for having my back
i agree in a hundred percent and i would appreciate that, too.
but i fear that this would be connected with a whole lot of technical effort for rapid,
as all streams have to be recoded with a hevc based codec.
(streams are currently encoded with H.264 codec, and would have to be recoded with the H.265/hevc codec)
any officials from rapid reading this here? mehdi, babak?
what do you think about this, gentlemen?
thx, regards
Set buffer size on settingsHello,GhostPhantom, Hekuran,
hello friends
thx, regards
bought a MAG256 last week and got the issues as described above.
An image freeze yesterday for hours....
Should I return my MAG256 underwarranty and get a MAG254 instead?
Sounds really stupid that you need to go for a downgrade to get rapid iptv working..
Any advice pls guys
How much should I set?Set buffer size on settingsHello,GhostPhantom, Hekuran,
hello friends
thx, regards
Any advice pls guys
Try 5 firstHow much should I set?Set buffer size on settingsHello,
Any advice pls guys
tx will tryTry 5 firstHow much should I set?Set buffer size on settings
MAG256 is supported.
See also the reation of @Rapid IPTV here: https://rapidiptv.com/threads/mag-256-box-with-hvec.2069/#post-21814
Check if there is Firmware updateTry 5 firstHow much should I set?
Hi thank you for the suggestion
i tried 10 before and it didn't work
when I get home ill try this one
and would be more than happy if this worked out
but frankly speaking I don't believe that makes a difference
but thank you anyways
Put google dns in lan settingsCheck if there is Firmware updateHi thank you for the suggestion
Hi cuvillier
that was the first thing I did after I bought the box.
So I think it's your network issue. Do you use ethernet câble ?Cuvillier, thank you for your time
i did that, too
it was also one of the first things I did
dns 8.8.8.8 and also 8.8.4.4
problem persists
malheureusement![]()
I have also posted same thread on the forum
