mag254.co.ukHello
Where i can buy cheap for EU country Mag 250 boxes ?
Thanks!
mag254.co.ukHello
same shitthat are not real boxes but fake indeed.. but i believe they are chinesenot japanese
I dont sell this box but i have customers that has it and they say that the box shuts down and you need to pull out the power cable for it to start working again. Is this a problem someone else has had and figured it out?
Hi,yesterday I was talk with one reseller he has same problem as you with few customers
Found any solutions?
Thank you,He have only to put Portal URL and Name, then restart and it's done.Hi, my friend have a MAG250 box but with other provider, he wants to try rapid, where and which Settings should he use for it to work? Is it enough for him to enter a URL into portal adres and then give Mac Adres to have a trial? Or does he have to do any other Settings for it to work? Since he bought the box with 1 year ACC from another service so im afraid that they maybe put some Settings that he would not be able to use rapid service.
How do u do that? We went to inner portal Settings and tried to find there but cant find portal menu only General and more not portal option.That's strange. Did you try to hard reset your device ?He have only to put Portal URL and Name, then restart and it's done.
My friend can't find to change portal. It only says general and more, he can't change portal url.
Go to : Menu—>Settings—>System Settings->Servers—>PortalsHow do u do that? We went to inner portal Settings and tried to find there but cant find portal menu only General and more not portal option.That's strange. Did you try to hard reset your device ?My friend can't find to change portal. It only says general and more, he can't change portal url.
Did that too. There is no option for "portals" only "general" and "more"Go to : Menu—>Settings—>System Settings->Servers—>PortalsHow do u do that? We went to inner portal Settings and tried to find there but cant find portal menu only General and more not portal option.That's strange. Did you try to hard reset your device ?
I can say that something is wrong with the box, you should replace it.Did that too. There is no option for "portals" only "general" and "more"Go to : Menu—>Settings—>System Settings->Servers—>PortalsHow do u do that? We went to inner portal Settings and tried to find there but cant find portal menu only General and more not portal option.
Is it possible for a iptv provider to Block/remove portal Settings somehow? He contacted the guy that sold him that and he just said that "if you want to try another service, then they should know how you do it" so i think theyve mixed with the box or somethingI can say that something is wrong with the box, you should replace it.Did that too. There is no option for "portals" only "general" and "more"Go to : Menu—>Settings—>System Settings->Servers—>Portals
I think maybe the box is locked to his original provider.Is it possible for a iptv provider to Block/remove portal Settings somehow? He contacted the guy that sold him that and he just said that "if you want to try another service, then they should know how you do it" so i think theyve mixed with the box or somethingI can say that something is wrong with the box, you should replace it.Did that too. There is no option for "portals" only "general" and "more"
Thank you for your advice!use the smartiptv portal address: http://mag.sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******, and go to http://sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/mylist/ and upodate your m3u link there
