Audio Settings for Mag STB
SERVICE PROVIDER portal Make sure your output is set to out mode = Stereo ,SPDIF mode = Bitstream
Inner portal settings Initial Volume = , 100 , Audio output mode = Stereo , F1 more settings , Dynamic range compression = Disabled , Operating Mode = Line Mode , Spdif Mode = Bitstream ,HDMI mode = PCM , Exit and reboot device
Thanks for the quick reply, and I'll give it a go as soon as I can access the inner portal again, which I made another thread about.
No need to keep openign threads just write it down here.
When going to internal portal doesnt work you need to ge back to factory settings and start over
I've got all the settings as you said but the volume is still low. There is no Dynamic range compression setting in the inner portal audio settings. My box is a ln infomir 256
