How to do a software update ??Yes you should try.No, should i
What is model of your MAG?How to do a software update ??Yes you should try.No, should i
Please look at here : https://wiki.infomir.eu/eng/stb-webkit/mag256-257/update-firmwareMag256 .. im getting the same error i did the uodate just now but still nothing
Good morning.
The problem I'm having is that when the box starts up a "Unlock / Password request" screen appears and I can't go any further.
Prior to this happening I have done a liitle looking through the menus and think that I may have caused the problem but I'm not sure.
The problem is, I don't know exactly what password the box is asking for.
I've tried the default password which I believe to be 0000 I've also reset the box to default settings and even reflashed the box using the recovery utility / USB with imageupdate file (Box reported "Flashed successfullly") but upon rebooting the problem persists.
I've attached a picture of the screen in question in the hope that someone might recognise the screen in question and be able to tell me exactly which password the box is asking for.
Thank you and regards, The Soulman.
You need a hard reset using MC update from infomirGood morning.
Good morning.
Send me a picture above from the mag box
Please go to infomir website they have a support forum about multicast hard reset as they will give you a special software to download to do a full hard resetYou need a hard reset using MC update from infomirGood morning.
Please could you explain what a hard reset using MC update from infomir is.
Regards, The Soulman.
No but the best way is to start from scratch using multicast resetPlease go to infomir website they have a support forum about multicast hard reset as they will give you a special software to download to do a full hard resetPlease could you explain what a hard reset using MC update from infomir is.
Thank you Earnmonitor.
Could I ask you, have you seen this password request screen before and please could you tell me what causes it to appear ?
Thats not a real mag. Its fake model.
The ones on Infomirs website are also fake ?I told you its a fake. A real mag does not have the mag text above.
