DerCremaxx
=Always here to Support you just pm me=
108
247
Germany
CodGlas
I think I'm not in it because the problems have been for 2 - 3 months, primarily in prime time
It most likely means that Telekom is slowing down the connection of the Customers during prime time this causes then problems on watching iptv streams
Milenko
Milenko
Can Be, but if I make a Speedtest at this time, everything's normal 100mbbs
MartinL
MartinLam
MAG 254, but tell me if I can work out IPTV on an android box liek Seguro trongle ?
withoutname
there is really an problem with the telekom. i have 3 friends an all of then have big problems!
1) 50 Mbits with a FritzBox 7590 on a fire tv stick, tested with siptv and kodi
2) 50 Mbits with a FritzBox 7362 on smart iptv on an samsung tv
3) 200 Mbits with a Speedport W724V on smart iptv on an lg tv
alle 3 have the same problems!
german iptv streams works great, romanian and ex yu are not working. they load few seconds and the stream stops every 1-2 second.
on all 3 we have tested other and different DNS, not better, same result.
the fire tv stick from friend 1 i have tested at my internet connection (50 mbits unitymedia) and all channels (romanian, ex yu) works without problems.
anyone an idea??
Reactions: Qiptv
Milenko
Milenko
Glad I'm not the only one.
Talked to the telekom several times, but you have no solution for me.
Telekom no longer send the vlan8 „to new connections“! Telekom says it cannot be because the vlan8 has not been broadcast since the beginning of the year but the problem has only recently been.
And the technicians of rapid don't know if you need the vlan8 because there s the difference to the other providers.
Reactions: withoutname
Orzabit
45
56
just be careful the newest version of mag 322 does not work with stalker anymore, so you would not be able to use the portal. Their new version only support
Ministra multiscreen TV platform
Pellep
Question.
If you have a 12 month subscription but have left for 6 months BUT the reseller has deleted MAC in the control panel, will you not access the channel list ?.
I have got a link from the dealer, but when downloaded, it's only 7bit big.
Cheers all :)
7,035
just open a ticket from your Dashboard. Your Reseller will help you to fix the issue.
Pellep
Thanks for your answer.
But reseller dont do nothing and have deleted my MAC even if i have more then 6months left on my subscription.
Thats why i ask this quastion.
7,035
we cannot help it out. You need to contact your Reseller. Because he has the access to your line.
sukimops
14
There is an actual version that can handle this windows 10 issue on manyplay
On my laptop with win 10 i must run the app with administrator rights because
webgrabplus stores a data file in a restricted folder:
x:\users\xyz\AppData\Local\WebGrab+Plus
Luciferek18
Hi can u explain to me where do I need to change it in my list in sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******?
ninjaef
Can it be done.
I do not fully undestand VPN yet, but there is an option to run my on VPN server on my router. Will this "unblock" IPTV streams which are being blocked as a result of SlyeUK action.
If not then why is a hosted cloud VPN needed. In fact, I would opt to create my own host in the cloud and install a VPN server on that. Much cheaperand faster but - why can it not be on the router?
ninjaef
Why do some streams:-
Freeze for a second maybe 3
Buffer
Go into a "loop" where video and sound abruptly stops and the last say 10 seconds of live TV is replayed then things carry on as normal.
These happen quite a lot, not just on your service though.
Why?
And its not my ISP or Router or Devices, because everyone using IPTV that I know (~50 people) have the SAME problems and they use different ISPs, different devices and some are not even in the same country.
I accept its part of IPTV but whats going on?
Gaby
22
75
38
Hi guys
I recently bought a 12 month subscription and got access to my dashboard.
From there i can download the M3U file that i need but there are so many options to choose from..
Which one is correct to download? I have a Samsung smart tv.
Davor
Trusted Reseller
127
59
41
bloodyczech
Hi guys
M3u with options MPEGTS
Reactions: Gaby
