Also portal otherwise the magboxes wont workDoes Rapid only provide m3u, not portal ?
@ this moment EPG is under constructionUsing Portal, will the EPG work ?
Im especially curious if it works for Swedish channels from Viasat and Canal Digital
Yes there is another question.
I dont even know what stalker middleware is.
I have tried a few providers, and there wasnt any talk about middleware.
It just worked anyway.
I just added the URL I got , that was it.
So what is this Middleware, and what does it do ?
Why do I need it ? Or dont I ?
Hi thereHello
I have an mxq 4k tv box, its running android 6.01 and is very slow as a browser. As the browser is important to me and most other applications are not, can I delete most of them and would that speed up the browser and how can I do that.
diode84
This would not help get a free clean apk installer it along with antivirus to check why it is slowHello
diode84
I have just got it new so it cant be full, I did reset it to original settings and installed kodi 17.1. Is it possible to just put on a basic operating system without any apps at all. Then install what I want.Hi thereHello
diode84
That Android box is a good " starter " box, But if your looking for att better experience in Web browsing is would suggest getting a faster box.
Deleting other apps on the box will not speed it up in this perticular case, In some rare cases when your memory is full the box will start to act wierd all over the place and not just in browser .
There are a few modded firmware to try out to get rid of bloatware, However you should be somewhat into flashing firmware and so on... And this will void any warrenty you might have.I have just got it new so it cant be full, I did reset it to original settings and installed kodi 17.1. Is it possible to just put on a basic operating system without any apps at all. Then install what I want.Hi thereHello
diode84
Its a very cheap box so warranty is not a problem. I will look on youtube But ideally I would put on linux but that seems full of problems.There are a few modded firmware to try out to get rid of bloatware, However you should be somewhat into flashing firmware and so on... And this will void any warrenty you might have.I have just got it new so it cant be full, I did reset it to original settings and installed kodi 17.1. Is it possible to just put on a basic operating system without any apps at all. Then install what I want.Hi there
You could try and look at the different clips on Youtube, Just search MXQ 4k Firmware and you will find it
But as i mentioned before, This box is great for streaming Iptv using Perfect player and to some extend Kodi, But for demanding tasks i would suggest a faster box whit better CPU and more RAM.
