still same, it freezes after some time and it doesn't react to the remote, the box just blinks, but nothing happens and there is no picture,,,
Hi i just upgraded Three MAG250 boxes and have the same problem. I just ordered the needed Components but what program do you use to operate the FT2232H card ?
I went for factory reset and after all that, menu or basic applications not seen. On restart it shows setting and browser symbol and in settings shows ethernet, wifi, time setting and software update but on trying new update nothings happens
Dear all.
My client have MAG250, Last two days have Page loading error. Internet is enabled, connected Wired and Wireless same problem. How to solve this problem?
Thank you
Infomir released new firmware and all boxes need to be updated. Use exactly portal that you give him and change DNS to 8.8.8.8 or 1.1.1.1 or 1.0.0.1
DNS on MAG box change to 8.8.8.8 or 1.1.1.1 or 1.0.0.1 > System settings > Network > Wired (Ethernet) > Auto (DHCP), manual DNS
Thank You. This solved the problem. I added manual DNS and portal is loaded.
Thank you again.
Dear Triton,
Thank you for your effort and the instruction. It all seems to work well.
Is V3 boards totally impossible to unbrick? Mine is V3. It all got stuck once i loaded the u-boot.o file.
Hi, I have a problem with a Mag 250 clone, I followed all the instructions, but I do not go any further where there is the transition with Hyperterminal, you can help me Thanks
Until here I've done it but in the very first step I'm stuck in favor if you can help me, Thanks
hello together, I have managed to get into life, but I still have a small problem, image about usb does not accept it, no image comes in USB, where is the error?
Thanks to who can help me on
Board: MAG250 [32-bit mode]
U-Boot 1.3.1 (Nov 7 2011 - 20:45:09) - stm23_0047
DRAM: 256 MiB
NOR: 1 MiB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Press "Menu" for enter menu
Hit any key to stop autoboot: 0
Warning: MAC addresses don't match:
HW MAC address: FF:FF:FF:FF:FF:FF
"ethaddr" value: AA:AA:AA:AA:AA:AA
Using MAC Address AA:AA:AA:AA:AA:AA
STM-GMAC: IC+ IP101 found
STM-GMAC: PHY address mismatch with hardware (hw 8 != 1)
STM-GMAC: PHY auto-negotiate timed out
STM-GMAC: *Warning* no link detected
BOOTP broadcast 1
STMAC: second tx timeout
BOOTP broadcast 2
STM-GMAC: tx timeout - no desc available
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
Retry count exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Hyperterminal
PLS Help My
Have you updated the u.boot file with HEX editor as described? Seems your MAC adress is invalid?
Hello to resolve a problem with faulty mag boxes you must downgrade firmware / flash older firmware then reset to default settings in blue menu that is accessible with menu button right after powering a box. After flashing old firmware disable automatic firmware update and update to newest firmware and do reset in blue menu again. Then insert your portal data and box should be ok. Regards
