Hello to resolve a problem with faulty mag boxes you must downgrade firmware / flash older firmware then reset to default settings in blue menu that is accessible with menu button right after powering a box. After flashing old firmware disable automatic firmware update and update to newest firmware and do reset in blue menu again. Then insert your portal data and box should be ok. Regards
