Do not Think it is supporter.Hello,
I've a iptv mag 250 but i can t record programms when i push F1.
Is it possible or not. Please give a solution if is it possible. Thanks
The same with my clients using mag250..."
Actually I have a problem while trying to load the iptv portal.
Usecase:
1. Start MAG254
2. Infomir start screen in loading
3. loading portal screen appears
4. Black screen
Now I just have a black screen, nothing is loading anymore. No blue background as it was some days ago. I just can push the menu button on my remot to get in the settings menu. Reload portal, rboot device etc. does not work.
Any idea what to do?
I have the same problem did you manage to solve it ?
Or does someone know how to solve it ?
I got internet and when i delete my mac adress from the dashboard i got the message ''your stb is blocked"
did you fix this, im kind of stuck like you...wont go into bios, stuck i tftpwhat is the file C0A8000B.img ?
can i transfer from computer to mag250 by tftp protocol?
Have you make sure that you changed the Boot type from DHCP to NAND inside the BIOS?I have followed the guide and it all worked as blue light now come on, however when box is reset and menu is pressed, it doesn't go to bios, i am stuck at the dchp and then to sft. can anyone help on this matter?
I saw the same problem with the Mag250. Is there any solution?Hello friends,
My clients using mag250 can not connect to the portal, when charging portal the stb reboot
Someone experience the same problem?
Solutions?
Thanks in advance.
Kind regards
Happy New year 2019 For All
Go into dashboard and select thoose country you dont want in your channel list. If the bouquet is smaller it will load the portal.I saw the same problem with the Mag250. Is there any solution?
Hello,I saw the same problem with the Mag250. Is there any solution?
thank you very much for the informationHello,
please remove unwanted bouquets from your dashboard or your memory may get full.
Afterwards, restart the router and your Mag Device and try again, please.
This has now been fixed, simple as change the batteries in the remote as its very weak. Allow me to get into bios.I have followed the guide and it all worked as blue light now come on, however when box is reset and menu is pressed, it doesn't go to bios, i am stuck at the dchp and then to sft. can anyone help on this matter?
please remove unwanted bouquets from your dashboardGoodmorning i am having the same issue with my mag 250 when its loading the portal it restrts before finshed loading and get stucked
Anyone has solved this problem
Thank you in advance
Can you suggest me a way or a link to do that i dont know howto delete bouquets, i allready deleted some old providers but stil the same problemplease remove unwanted bouquets from your dashboard
In the inner portal go to settings/system settings/network and What ever option u use for your internet change from auto-DHCP to auto-dhcp/manual dns. And on manual dns you put 8.8.8.8 save and reboot. IF still same problem you should try to contact support of your portal. Cause then your ip is blocked. So its either a dns problem with your internet provider or your ip is blocked from portal.Actually I have a problem while trying to load the iptv portal.
Usecase:
1. Start MAG254
4. Black screen
Thread starter | Similar threads | Forum | Replies | Date |
![]() | Technical issues - Need Professional Help | GSE Player | 0 | |
![]() | MAG 351/352 Technical Issues | MAG 351/352 | 7 | |
![]() | Formuler Z7+ Technical Issues | Formuler Z7+ | 87 | |
![]() | MAG: Technical Issues | MAG Device | 202 | |
![]() | Nvidia Shield Technical Issues | Nvidia Shield | 27 |
