I have the same problem. It started when i updated to latest firmware. It seems to be all Vod that have DTS-sound.
Hope someone have any solution for this soon ?
Yes I didn’t recall anything before I updated to the new firmware can’t think why it wouldn’t support DTS poor by infomir would make sense why some sound movies play & others don’t seem somewhere the 322 had same fault they had a firmware update to solve it
I downloaded this file
http://soft.infomir.com/mag256/release/2.20.03/imageupdate
and saved it on my USB stick in a folder called mag256.
Downgrade imageupdate:
1. Connect prepared USB-drive to STB.
2. Enter the System Recovery Utility menu :
a. Power off (unplug the power supply) STB.
b. Push and hold Menu button on RC and power STB on (still Holding Menu button, plug in power supply).
c. Wait for (~10 seconds) System Recovery Utility menu.
Release Menu button.
3. Select Upgrade Tools ⇒ Upgrade Software ⇒ Using USB ⇒ Yes; and select your file.
4. Wait until the update process is complete. The info about software update status is displayed in the bottom of screen.
When the software is updated the STB will automatically reboot.
Note: the Menu botton on RC is located on the left hand side below the down button and above the Vol+ button. The one with the 3 lines and 3 dots.
Good luck :)
Good luck :)
Before you downgrade, don't forget to didable automatic update in the Embedded Portal:
1. Load Embedded Portal
2. Select Settings
3. Select Software autoupdate
4. In Autoupfate select Disabled
5. Press OK to save the changes.
Ive connected a supported adapter but just get the Wi-fi adaptet not connected error when trying to go to the settings.
What am I doing wrong?
Its a TLWN722N adapter and a regular mag256 box.
I took with me my box on vacation and I can not watch the channels, why?
Is it somehowe loocked at my home or what?
The internet is good and I can play games on my computer , plz help!
Best regards
It seems that infomir has deleted there older firmwares :O
I cant find 2.20.03 for mag256. Do u stil have the image downloaded @fascinity ? Can u share it with me please ? :)
Best regards
Where are you on vacation?
Try to reset your box on factory deafult
Hi all i load my magbox257 up and it's stuck on infomir load up screen giving me no options to do anything?
