Yes ismarttv. my magbox can be directly plugged in or it can also use wifi. In my case I use the wifi because i share a house and my lanlord has the modem and router in her room. I hope you have seen this before and knowhow to fix it..never had a problem then all ofa sudden this!. Thanks
Then I will consider it a defective box. My first MAG 256w2 was also defective. It restarted all the time, so I could not get into the menu once.
I have the exact same problem on my mag254, i have tried many different things factory default, installing an older firmware and no matter what the volume is very low. Before the problem started i use put my soundbar on 9 out 50 and would be loud, after the update i have to put i at 40 out 50 just to be able to hear voices.hi! i have a problem...
after apdate to my mag 254 the sound is low and don't change with remote... what is the problem?
Yes, it support HEVC
Hello. The MAG boxes come and update the EPG automatically. You do not have to do anything.Hi guys i recently bought a mag box 256/w2 and tried using the epg but there is absolutely nothing there. How can i get the epg working ?
Hi, On the remote there is a button labelled ‘APP’. Use this to select subtitle options if available.
