It's something with Rapid that's not allowing some boxes to connect to The portal on M3U it works on MAG and Tvip boxes,
It works with other providers I have tried
I have tried with MAG 254 and Tvip 410 and 600,
The portal with Rapid can't connect I have tried different portals It's The same.
Some Times it works after many tries but if you restart box or Reload portal, It's The same
Was the same on my Mag351.
Tried all of the suggestions above without result.
Now I have done a "cleare user data" in the advanced main menu, and my box started again and is working fine.
I have not restarted yet because I dont want get stuck again. :blush:
For MAG256 users: Goes to system setting "Software update" after update it worked again for me.
Bevore the update i had the same issues with black screen and so on..
what i normally do is let them unplug the box.
on dashboard i change there password ( so the line will reconnect with server)
delete mac address and add it again.
and than let them restart the box again.
in the last 30 casses 29 got image back again
I did this with MAG 254 and it works
this looks like a problem in the informir firmware has problem opening the xstream codec. only box 256 shows this problem.
As temporary solution this works as a charm
Mijn dank is groot :) thanks rusax
Still having the same problem I also updated my MAG351
yesterday, i had 2 boxes that also gave only black screen on the old dns clientportal and mine own.
i changend it to the new dns found in settings on the right side and both are working without problem now
Hmm, I've just checked, my MAG portal is still the same URL? o_O
Yeah it can be, i had some clients on old dns and a private one i made with cloudflare. so its possible you still have the same
