BrokenChaos
Hi guys,
finally I found this forum again so I can ask you for help
I bought a Mag 256 a month ago and I have a strange issue with the box. I use the Siptv portal btw.
I edited my list with xtream-editor and it worked well but whenever I switched the channels quickly, the channels stopped working. It said connecting but nothing happened. So I had to hard restart the box. The same happened when I tried to open a channel which didn´t work. Then no channel worked and I need to restart again. That´s really depressing.
I thought it was a problem that came with the custom xtream list so I loaded the original list and it worked with fast switching channels but I still have the problem that none of the channels work until I do a hard restart when I try to open a channel that doesn´t work.
Can anyone relate with this? Does anybody have a solution?
So it worked with the old list but not new list?
Not sure how a routing change would be the issue...
