Ok. Cool.not we...rapidiptv guys have this do to
We won't delete logos from our server.Ok. Cool.not we...rapidiptv guys have this do to
also I can't seem to change the order of my favourites. Do you have this problem. I move them but they don't stay in the order I put them.
Having logos is a good option for us, so we can't remove one of our advantages.We won't delete logos from our server.Ok. Cool.
So we are always going to have this scrolling problem? You are going to have some very unhappy people with MAG boxes!
there must be a solution!
I use stb Emulator PRO on my minix x7. Try to select all channels and press sort, by favorite, you will have all your favorite channels display in One listCool- thx. Will give that a go.
Can I ask you- I can't move my favourites into an order so they stay there. Do you have a Mag Box? Am I being an idiot?
Just waiting that the french list will be edited...It's slow with all folders or only uk folder?
for me it's better on spanish folder but for french folder, the scrowlîg is slow.
i tested an other provider and it's true i didn't have low scrowling
Try my idea.@Rapid IPTV But this one small advantage creates a very big disadvantage for us MAG users. Maybe you could disable the logos for a little while just for us to test if the scrolling speeds up. That way we have the problem pinpointed at least.
I tried that already, it changed nothing. Just as slow as before.Try my idea.@Rapid IPTV But this one small advantage creates a very big disadvantage for us MAG users. Maybe you could disable the logos for a little while just for us to test if the scrolling speeds up. That way we have the problem pinpointed at least.
I agree with macdennis@Rapid IPTV But this one small advantage creates a very big disadvantage for us MAG users. Maybe you could disable the logos for a little while just for us to test if the scrolling speeds up. That way we have the problem pinpointed at least.
I will change something (disable logos temporarily) see if it changes something...I agree with macdennis@Rapid IPTV But this one small advantage creates a very big disadvantage for us MAG users. Maybe you could disable the logos for a little while just for us to test if the scrolling speeds up. That way we have the problem pinpointed at least.
it will be a good test to know if the problem are the logos
yes the problem are the logo
now i have perfect speed scrowling without the logos
hmmm ok. no more logo for channels....we have to consider this....Now the speed is perfect, no more slow scrolling.
