Alright, I fixed it :D
For everyone suffering from the "wrong signature" problem, pull the cable, press the menu button, put in the cable, hold it until it enters BIOS, then update from the USB through the recovery/BIOS screen. It'll work then.
Menu button??
Is is always the same ! People ask first, without searching in this forum. There are thousands of questions and answers in hundreds of threads - mostly you will find your answer if you are searching.
But it is easier to ask and steal the time of other people. I do not answer any more if I could find the answer easly if I am searching - not even provide the answer link :p
I am getting this also with a customer, i added mac to stbemu and its fine, but on the physical mag still blocked. tried usual change pass and remove/add mac
Has the client given you the right Mac Code?
The person before had the same problems and his friend had given WRONG MAC CODE
O
nce he changed it to the right Mac Code its working fine
lucianus_luciferus
Nov 8, 2018 17 7 3
Yesterday at 9:34 PM
but it is working now. he wrote wrong mac :)
Reactions: Sandrito
O
This is wonderful THE RESELLER doesn't even apreciate us helping them (evan a small message wether it helped them or not would have meant a lot to us trying to help) seems like they are very quick to ask, but never to appreciate us :(
All, I am trying to add a new MAG and getting the error message that the requested DATA does not match? Any idea why?
